Einleitung
These three buttons supply the Nikon Coolpix AW130 with its supplementary features such as instantaneous sharing and location services. Nevertheless, they can become easily dirtied by underwater adventures and off-roading.
Was du brauchst
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
After pressing the yellow tab, the battery should loosen.
Slowly pull the battery completely out.
Using the spudger, pry the plastic button face from the camera body.
Using tweezers from the precision tweezer set, remove the buttons from the larger plastic piece.
Using tweezers from the precision tweezer set, remove the silicon backing from the buttons.
From there, the buttons should dislodge from their plastic casing.
