Zum Hauptinhalt wechseln
Nikon Coolpix B700 Button Assembly Replacement
Was du brauchst
  1. Nikon Coolpix B700 Button Assembly Replacement, Back Frame Assembly: Schritt 1, Bild 1 von 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Button Assembly Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Button Assembly Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix B700 Button Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Button Assembly Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Button Assembly Replacement: Schritt 5, Bild 1 von 3 Nikon Coolpix B700 Button Assembly Replacement: Schritt 5, Bild 2 von 3 Nikon Coolpix B700 Button Assembly Replacement: Schritt 5, Bild 3 von 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Button Assembly Replacement: Schritt 6, Bild 1 von 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Button Assembly Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix B700 Button Assembly Replacement: Schritt 7, Bild 2 von 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Button Assembly Replacement, Button Assembly: Schritt 8, Bild 1 von 1
    • Lift the corner under the power button up.
    • While at the same time pushing the selector knob back.
  9. Nikon Coolpix B700 Button Assembly Replacement: Schritt 9, Bild 1 von 1
    • This should remove the entire assembly from the camera housing.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 422
