Zum Hauptinhalt wechseln
Nikon Coolpix B700 Flash Unit Replacement
Was du brauchst
  1. Nikon Coolpix B700 Flash Unit Replacement, Back Frame Assembly: Schritt 1, Bild 1 von 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Flash Unit Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Flash Unit Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Flash Unit Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Flash Unit Replacement: Schritt 5, Bild 1 von 3 Nikon Coolpix B700 Flash Unit Replacement: Schritt 5, Bild 2 von 3 Nikon Coolpix B700 Flash Unit Replacement: Schritt 5, Bild 3 von 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Flash Unit Replacement: Schritt 6, Bild 1 von 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Flash Unit Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement: Schritt 7, Bild 2 von 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Flash Unit Replacement, Internal Bracket: Schritt 8, Bild 1 von 1
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
  9. Nikon Coolpix B700 Flash Unit Replacement: Schritt 9, Bild 1 von 1
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Flash Unit Replacement: Schritt 10, Bild 1 von 1
    • Move the ribbon out of the way to reveal the hidden screw.
  11. Nikon Coolpix B700 Flash Unit Replacement: Schritt 11, Bild 1 von 1
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Flash Unit Replacement: Schritt 12, Bild 1 von 1
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Flash Unit Replacement: Schritt 13, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement: Schritt 13, Bild 2 von 2
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Flash Unit Replacement: Schritt 14, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement: Schritt 14, Bild 2 von 2
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Flash Unit Replacement: Schritt 15, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement: Schritt 15, Bild 2 von 2
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
  16. Nikon Coolpix B700 Flash Unit Replacement, Lens Assembly: Schritt 16, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement, Lens Assembly: Schritt 16, Bild 2 von 2
    • Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
  17. Nikon Coolpix B700 Flash Unit Replacement: Schritt 17, Bild 1 von 1
    • Remove the tripod mount from it's slot.
  18. Nikon Coolpix B700 Flash Unit Replacement: Schritt 18, Bild 1 von 3 Nikon Coolpix B700 Flash Unit Replacement: Schritt 18, Bild 2 von 3 Nikon Coolpix B700 Flash Unit Replacement: Schritt 18, Bild 3 von 3
    • Now you just have to slide the lens assembly out of the housing.
  19. Nikon Coolpix B700 Flash Unit Replacement, Motherboard: Schritt 19, Bild 1 von 1
    • Use the metal spudger to open the latch to remove the ribbon.
  20. Nikon Coolpix B700 Flash Unit Replacement: Schritt 20, Bild 1 von 1
    • Use the Phillips screwdriver to remove the single 6 mm screw.
  21. Nikon Coolpix B700 Flash Unit Replacement: Schritt 21, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement: Schritt 21, Bild 2 von 2
    • Gently lift the button assembly. Slide the motherboard out from the shell.
  22. Nikon Coolpix B700 Flash Unit Replacement: Schritt 22, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement: Schritt 22, Bild 2 von 2
    • Desolder the black, gray, and white wires from the motherboard.
    • The motherboard is labeled with the wire colors.
  23. Nikon Coolpix B700 Flash Unit Replacement, Flash Unit: Schritt 23, Bild 1 von 1
    • Using a Phillips screwdriver, remove the two 6 mm screws that hold the flash assembly.
  24. Nikon Coolpix B700 Flash Unit Replacement: Schritt 24, Bild 1 von 2 Nikon Coolpix B700 Flash Unit Replacement: Schritt 24, Bild 2 von 2
    • Now while pushing the flash button slide out the flash assembly from the housing.
    • The flash button could fall out when the assembly is removed.
    • During reassembly, insert the flash unit assembly first, then reconnect the flash button.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 430
