Zum Hauptinhalt wechseln
Nikon Coolpix B700 Lens Assembly Replacement
Was du brauchst
  1. Nikon Coolpix B700 Lens Assembly Replacement, Back Frame Assembly: Schritt 1, Bild 1 von 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 5, Bild 1 von 3 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 5, Bild 2 von 3 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 5, Bild 3 von 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 6, Bild 1 von 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 7, Bild 2 von 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Lens Assembly Replacement, Internal Bracket: Schritt 8, Bild 1 von 1
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
  9. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 9, Bild 1 von 1
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 10, Bild 1 von 1
    • Move the ribbon out of the way to reveal the hidden screw.
  11. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 11, Bild 1 von 1
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 12, Bild 1 von 1
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 13, Bild 1 von 2 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 13, Bild 2 von 2
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 14, Bild 1 von 2 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 14, Bild 2 von 2
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 15, Bild 1 von 2 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 15, Bild 2 von 2
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
  16. Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: Schritt 16, Bild 1 von 2 Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: Schritt 16, Bild 2 von 2
    • Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
  17. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 17, Bild 1 von 1
    • Remove the tripod mount from it's slot.
  18. Nikon Coolpix B700 Lens Assembly Replacement: Schritt 18, Bild 1 von 3 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 18, Bild 2 von 3 Nikon Coolpix B700 Lens Assembly Replacement: Schritt 18, Bild 3 von 3
    • Now you just have to slide the lens assembly out of the housing.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
how to reset an objective error on B700 ? the lens is stopped in the middle of a hike
Per Benny Paulsen - Antwort
how to reset an objective error? the lens is stopped in the middle of a hike
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 39
Insgesamt: 2,617
