Einleitung
This guide will walk you through the necessary steps to remove the back panel of the Nikon Coolpix E5700.
Was du brauchst
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
Open the battery door.
Turn to the bottom of the camera.
Remove the two Phillips screws located directly below the back monitor
Turn the camera to the side with the memory card slot and open the compartment for the CF card.
Remove the top two Phillips screws closest to the back panel.
Turn to the back of the camera.
Remove the top most Phillips screw on the back panel.
Turn to the last side of the back panel.
Remove the Phillips screw below the eyepiece.
Remove the Phillips screw located above the speaker.
2 weitere Personen haben diese Anleitung absolviert.
