Einleitung
This guide will walk you through the necessary steps to access and remove the LCD screen in the Nikon Coolpix E5700.
Was du brauchst
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
Open the battery door.
Remove two Phillips screws (3.4 mm) located on the left side of the screen.
Remove the metal bar on the left side of the screen.
Remove the screen from the front plastic housing.
Eine weitere Person hat diese Anleitung absolviert.
