Zum Hauptinhalt wechseln
Nikon Coolpix E5700 Rear LCD Replacement
Was du brauchst
  1. Nikon Coolpix E5700 Rear LCD Replacement, Battery: Schritt 1, Bild 1 von 2 Nikon Coolpix E5700 Rear LCD Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Rear LCD Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Rear LCD Replacement, Rear LCD: Schritt 3, Bild 1 von 1
    • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
  4. Nikon Coolpix E5700 Rear LCD Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix E5700 Rear LCD Replacement: Schritt 4, Bild 2 von 2
    • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
  5. Nikon Coolpix E5700 Rear LCD Replacement: Schritt 5, Bild 1 von 2 Nikon Coolpix E5700 Rear LCD Replacement: Schritt 5, Bild 2 von 2
    • Remove back plastic monitor cover.
  6. Nikon Coolpix E5700 Rear LCD Replacement: Schritt 6, Bild 1 von 1
    • Remove the Phillips screw on the top right side of the screen.
  7. Nikon Coolpix E5700 Rear LCD Replacement: Schritt 7, Bild 1 von 1
    • Carefully unplug the grey bundle of wires in the white housing.
  8. Nikon Coolpix E5700 Rear LCD Replacement: Schritt 8, Bild 1 von 1
    • Carefully unplug the small pink and wires in the grey housing.
  9. Nikon Coolpix E5700 Rear LCD Replacement: Schritt 9, Bild 1 von 1
    • Remove the two Phillips screws on the left side of the screen.
  10. Nikon Coolpix E5700 Rear LCD Replacement: Schritt 10, Bild 1 von 1
    • Remove the metal bar on the left side of the screen.
    • Remove the screen from the front plastic housing.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kyle Sitton
351 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 24-58, Amido Spring 2011 Mitglied von Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 2,431
