Zum Hauptinhalt wechseln
Nikon Coolpix L16 LCD screen replacement
Was du brauchst
  1. Nikon Coolpix L16 LCD screen replacement, LCD: Schritt 1, Bild 1 von 3 Nikon Coolpix L16 LCD screen replacement, LCD: Schritt 1, Bild 2 von 3 Nikon Coolpix L16 LCD screen replacement, LCD: Schritt 1, Bild 3 von 3
    • Clearly visible damage to the LCD. It did not even light up.
    • Remove the screw from the right side.
    • Remove the visible screw from the left side.
    Frag FixBot
    Kommentar hinzufügen
  2. Nikon Coolpix L16 LCD screen replacement: Schritt 2, Bild 1 von 3 Nikon Coolpix L16 LCD screen replacement: Schritt 2, Bild 2 von 3 Nikon Coolpix L16 LCD screen replacement: Schritt 2, Bild 3 von 3
    • Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers...
    • Remove the three screws from the bottom.
    • Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
    Frag FixBot
  3. Nikon Coolpix L16 LCD screen replacement: Schritt 3, Bild 1 von 3 Nikon Coolpix L16 LCD screen replacement: Schritt 3, Bild 2 von 3 Nikon Coolpix L16 LCD screen replacement: Schritt 3, Bild 3 von 3
    • After the splitting of the case, the LCD is imediately visible.
    • Lift the LCD out of the frame by using your fingernail or an opening tool. Do not remove it yet, it is still connected.
    • Flip the black clasp up by using fingernails or the opening tool. No big force is required. Remove the old LCD.
    Frag FixBot
  4. Nikon Coolpix L16 LCD screen replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix L16 LCD screen replacement: Schritt 4, Bild 2 von 2
    • Here is the new screen, note the blue tab. This is the screen protector, remove it after installation.
    • Reassemble in reverse order. Hopefully your results will be the same as for me.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
oldturkey03
856.092 Reputation
123 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 75
Insgesamt: 3,772
