Einleitung
In order to reach the internal elements of the camera (LCD screen, motherboard, lens, etc.), the following steps will tell you how to remove the back cover.
Was du brauchst
Remove the memory stick from the camera.
Remove the batteries from the camera.
Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
There is one screw hidden under the AV cover that also needs to be removed.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
