Zum Hauptinhalt wechseln
Nikon Coolpix L18 Front Cover Replacement
Was du brauchst
  1. Nikon Coolpix L18 Front Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Front Cover Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix L18 Front Cover Replacement: Schritt 2, Bild 2 von 2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Front Cover Replacement: Schritt 3, Bild 1 von 1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Front Cover Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 Front Cover Replacement: Schritt 5, Bild 1 von 1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 Front Cover Replacement: Schritt 6, Bild 1 von 1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  7. Nikon Coolpix L18 Front Cover Replacement, Front Cover: Schritt 7, Bild 1 von 1
    • Pry back the front cover of the camera starting from the right side.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrea Govea
360 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 9-23, Regan Fall 2010 Mitglied von Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 3,248
