Zum Hauptinhalt wechseln
Nikon Coolpix L18 Lens Replacement
Was du brauchst
  1. Nikon Coolpix L18 Lens Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Lens Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix L18 Lens Replacement: Schritt 2, Bild 2 von 2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Lens Replacement: Schritt 3, Bild 1 von 1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Lens Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 Lens Replacement: Schritt 5, Bild 1 von 1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 Lens Replacement: Schritt 6, Bild 1 von 1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  7. Nikon Coolpix L18 Lens Replacement, Front Cover: Schritt 7, Bild 1 von 1
    • Pry back the front cover of the camera starting from the right side.
  8. Nikon Coolpix L18 Lens Replacement, Lens: Schritt 8, Bild 1 von 2 Nikon Coolpix L18 Lens Replacement, Lens: Schritt 8, Bild 2 von 2
    • Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
    • Remove the LCD base plate.
  9. Nikon Coolpix L18 Lens Replacement: Schritt 9, Bild 1 von 1
    • Gently pull the lens ribbon out.
  10. Nikon Coolpix L18 Lens Replacement: Schritt 10, Bild 1 von 1
    • Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
  11. Nikon Coolpix L18 Lens Replacement: Schritt 11, Bild 1 von 1
    • Lift up the black and copper covering on the left side of the camera.
  12. Nikon Coolpix L18 Lens Replacement: Schritt 12, Bild 1 von 1
    • Pull the wiring at the top right of the camera away from the lens with tweezers.
  13. Nikon Coolpix L18 Lens Replacement: Schritt 13, Bild 1 von 1
    • Remove the cross-hair shaped wire cap to the left of the lens.
  14. Nikon Coolpix L18 Lens Replacement: Schritt 14, Bild 1 von 2 Nikon Coolpix L18 Lens Replacement: Schritt 14, Bild 2 von 2
    • Remove the 3 screws holding the lens to the camera frame.
    • Two 3.8mm black Phillips #00 screws on the sides of the lens.
    • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
  15. Nikon Coolpix L18 Lens Replacement: Schritt 15, Bild 1 von 1
    • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrea Govea
360 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 9-23, Regan Fall 2010 Mitglied von Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
sdalimon - Antwort
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
Alberto Lopes - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 16,944
