Zum Hauptinhalt wechseln
Nikon Coolpix L27 Screen Replacement
Was du brauchst
  1. Nikon Coolpix L27 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Nikon Coolpix L27 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Nikon Coolpix L27 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
    Frag FixBot
  2. Nikon Coolpix L27 Screen Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix L27 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 5 mm Phillips #000 screws from the left side.
    Frag FixBot
  3. Nikon Coolpix L27 Screen Replacement: Schritt 3, Bild 1 von 3 Nikon Coolpix L27 Screen Replacement: Schritt 3, Bild 2 von 3 Nikon Coolpix L27 Screen Replacement: Schritt 3, Bild 3 von 3
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
    Frag FixBot
  4. Nikon Coolpix L27 Screen Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix L27 Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
    Frag FixBot
  5. Nikon Coolpix L27 Screen Replacement: Schritt 5, Bild 1 von 3 Nikon Coolpix L27 Screen Replacement: Schritt 5, Bild 2 von 3 Nikon Coolpix L27 Screen Replacement: Schritt 5, Bild 3 von 3
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
    Frag FixBot
  6. Nikon Coolpix L27 Screen Replacement: Schritt 6, Bild 1 von 1
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
    Frag FixBot
  7. Nikon Coolpix L27 Screen Replacement: Schritt 7, Bild 1 von 1
    • Lightly push back the white switch holding in the screen cable
    Frag FixBot
  8. Nikon Coolpix L27 Screen Replacement: Schritt 8, Bild 1 von 2 Nikon Coolpix L27 Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the cable from the camera.
    • Lift the screen out.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
York University, Team R-25, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-25, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG25
1 Mitglied
1 Anleitung geschrieben
2 Kommentare zur Anleitung
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - Antwort Teilen
where can i buy a screen replacement please
mo0nflwr - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 15
Letzte 30 Tage: 80
Insgesamt: 1,736
