Zum Hauptinhalt wechseln
Nikon Coolpix L320 LCD Replacement
Was du brauchst
  1. Nikon Coolpix L320 LCD Replacement, Batteries: Schritt 1, Bild 1 von 2 Nikon Coolpix L320 LCD Replacement, Batteries: Schritt 1, Bild 2 von 2
    • Flip the camera over to reveal the card/battery door.
    • Slide the button to the unlocked position and the door should pop open.
    Frag FixBot
    Kommentar hinzufügen
  2. Nikon Coolpix L320 LCD Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix L320 LCD Replacement: Schritt 2, Bild 2 von 2
    • Take out the old batteries.
    • Look at the yellow sticker inside of the the battery compartment. You'll see the symbol for the direction the new battery should face when replaced.
    • The “+” means to put the raised end facing up. The “-“ means to put the flat end up.
    Frag FixBot
  3. Nikon Coolpix L320 LCD Replacement, LCD: Schritt 3, Bild 1 von 3 Nikon Coolpix L320 LCD Replacement, LCD: Schritt 3, Bild 2 von 3 Nikon Coolpix L320 LCD Replacement, LCD: Schritt 3, Bild 3 von 3
    • Use a JIS screwdriver to remove seven screws from the frame of camera.
    Frag FixBot
  4. Nikon Coolpix L320 LCD Replacement: Schritt 4, Bild 1 von 1
    • Use an opening tool or spudger to separate the front and back of the camera.
    Frag FixBot
  5. Nikon Coolpix L320 LCD Replacement: Schritt 5, Bild 1 von 1
    • Use a JIS screwdriver to remove the screws connecting the LCD to the motherboard.
    Frag FixBot
  6. Nikon Coolpix L320 LCD Replacement: Schritt 6, Bild 1 von 1
    • Gently flip the LCD over to reveal a ribbon cable connected to the motherboard.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector. Then, you can safely pull the cable out.
    • Remove the LCD screen from the camera.
    Frag FixBot
Abschluss
UMass Dartmouth, Team 5-6, Ramos Spring 2023 Mitglied von UMass Dartmouth, Team 5-6, Ramos Spring 2023
UMASSD-RAMOS-S23S5G6
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 9
Letzte 30 Tage: 38
Insgesamt: 615
