Einleitung
Use this guide to replace a scratched or damaged back plate.
This guide requires removing the back housing of the camera. When replacing the housing, use a PH000 screwdriver. The cover is well secured, so some force may be needed to remove the screws as well as the cover.
Was du brauchst
There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
Two 1.5x2.5mm screws on the right side.
Two 1.5x2.5mm screws on the underside.
Two 1.5x2.5mm screw on the left side.
After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
Remove the back housing of the camera by lifting it directly up.
