Zum Hauptinhalt wechseln
Nikon Coolpix L330 Back Housing Replacement
Was du brauchst
  1. Nikon Coolpix L330 Back Housing Replacement, Back Housing: Schritt 1, Bild 1 von 3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: Schritt 1, Bild 2 von 3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: Schritt 1, Bild 3 von 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Back Housing Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix L330 Back Housing Replacement: Schritt 2, Bild 2 von 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
Abschluss
Taibah
121 Reputation
1 Anleitung geschrieben
USF Tampa, Team 2-10, Cagle Spring 2016 Mitglied von USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 555
