Einleitung
Follow this step by step guide for memory card replacement.
Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera.
If the camera lens is pointing towards you, there should be a small lever on the right hand side.
Take this lever and push it away from your body, while simultaneously pulling upwards.
Gently press down on the memory card until you hear a click, then release the pressure to eject the card and slowly pull it upwards out of the slot.
2 weitere Personen haben diese Anleitung absolviert.
