Zum Hauptinhalt wechseln
Nikon Coolpix L610 Camera Lens Replacement
Was du brauchst
  1. Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: Schritt 1, Bild 1 von 2 Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: Schritt 1, Bild 2 von 2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Camera Lens Replacement: Schritt 2, Bild 1 von 1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Camera Lens Replacement: Schritt 3, Bild 1 von 1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Camera Lens Replacement: Schritt 4, Bild 1 von 3 Nikon Coolpix L610 Camera Lens Replacement: Schritt 4, Bild 2 von 3 Nikon Coolpix L610 Camera Lens Replacement: Schritt 4, Bild 3 von 3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Camera Lens Replacement, Control Panel: Schritt 5, Bild 1 von 3 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: Schritt 5, Bild 2 von 3 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: Schritt 5, Bild 3 von 3
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Camera Lens Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
  7. Nikon Coolpix L610 Camera Lens Replacement, Removing the screen: Schritt 7, Bild 1 von 1
    • Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
  8. Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: Schritt 8, Bild 1 von 2 Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: Schritt 8, Bild 2 von 2
    • While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
  9. Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: Schritt 9, Bild 1 von 3 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: Schritt 9, Bild 2 von 3 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: Schritt 9, Bild 3 von 3
    • Remove the 6 (3.70 mm) screws on the metal cover. Two of those screws are covered by black plastic covers.
    • After removing the screws the panel should come off and will look like the final image.
    • Be careful of the red and black wires on the top. If the flash is charged you could get a mild shock.
  10. Nikon Coolpix L610 Camera Lens Replacement: Schritt 10, Bild 1 von 1
    • Unplug the two ribbons for the lens. There will be latch that will need to be slid down. After loosening the latch, the ribbon should be able to be easily pulled out.
  11. Nikon Coolpix L610 Camera Lens Replacement: Schritt 11, Bild 1 von 2 Nikon Coolpix L610 Camera Lens Replacement: Schritt 11, Bild 2 von 2
    • Remove the 3 (3.10 mm) screws that are located on the back of the lens cover.
  12. Nikon Coolpix L610 Camera Lens Replacement: Schritt 12, Bild 1 von 3 Nikon Coolpix L610 Camera Lens Replacement: Schritt 12, Bild 2 von 3 Nikon Coolpix L610 Camera Lens Replacement: Schritt 12, Bild 3 von 3
    • There are two lens covers that will fall out after removing the back lens plate.
    • Remove the 6 (4.35 mm) screws surrounding the lens.
    • There are 2 more (3.70 mm) screws covered by a small black square located. Remove the black squares and proceed to unscrewing these final screws.
    • Remove the lens. It should just be free to pull it out.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Jeremy
1.072 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 9-4, Brown Winter 2015 Mitglied von USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 31
Insgesamt: 2,507
