Zum Hauptinhalt wechseln
Nikon Coolpix L610 Control Panel Replacement
Was du brauchst
  1. Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: Schritt 1, Bild 1 von 2 Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: Schritt 1, Bild 2 von 2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Control Panel Replacement: Schritt 2, Bild 1 von 1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Control Panel Replacement: Schritt 3, Bild 1 von 1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Control Panel Replacement: Schritt 4, Bild 1 von 3 Nikon Coolpix L610 Control Panel Replacement: Schritt 4, Bild 2 von 3 Nikon Coolpix L610 Control Panel Replacement: Schritt 4, Bild 3 von 3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Control Panel Replacement, Control Panel: Schritt 5, Bild 1 von 3 Nikon Coolpix L610 Control Panel Replacement, Control Panel: Schritt 5, Bild 2 von 3 Nikon Coolpix L610 Control Panel Replacement, Control Panel: Schritt 5, Bild 3 von 3
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Control Panel Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
Abschluss
Jeremy
1.027 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 9-4, Brown Winter 2015 Mitglied von USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 556
