Einleitung
The motherboard is what makes the camera work. If your camera stops working, follow this guide to replace the motherboard.
Was du brauchst
Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
Remove the plastic component located directly behind the flash from its rubberized holder.
Unsolder all the wires that are on the top of the motherboard near the flash component.
2 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
The guide is incomplete! Do not try to remove the mobo for it is soldered to some other tiny board under the on/off switch. Trying to remove the mobo after just unscrewing it, may guide to certain and permanent destruction of both PCBs!!!
This guide should be for beginners, Mr. Symeon Leriou, and you will not only write "Mobo", but also motherboard or Mainboard or Hauptplatine (deutsch)
But I agree with you that it is not complete.
The motherboard is soldered to the on / off board (power supply for the batteries).
Soldering again is almost impossible ...
