Einleitung
The device ports on a digital camera can be prone to damage that may render them nonfunctional. This guide will lead you through the necessary steps to replace damaged device ports.
Was du brauchst
Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
Remove the front top Phillips screw with the screwdriver.
Open the empty battery slot on the bottom of the camera, revealing four additional screws.
Unscrew the four Phillips screws with the screwdriver.
Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
Once the rear housing is separated, the settings buttons will be accessible for replacement.
Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
Using the pointed end of the spudger, lift the hinges that secure these four flex circuits.
Once the flex circuits are removed, the motherboard can be lifted and the device can be accessed for replacement.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
