Zum Hauptinhalt wechseln
Nikon Coolpix L820 Device Ports Replacement
Was du brauchst
  1. Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: Schritt 1, Bild 1 von 3 Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: Schritt 1, Bild 2 von 3 Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: Schritt 1, Bild 3 von 3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 Device Ports Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix L820 Device Ports Replacement: Schritt 2, Bild 2 von 2
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 Device Ports Replacement: Schritt 3, Bild 1 von 3 Nikon Coolpix L820 Device Ports Replacement: Schritt 3, Bild 2 von 3 Nikon Coolpix L820 Device Ports Replacement: Schritt 3, Bild 3 von 3
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
  4. Nikon Coolpix L820 Device Ports Replacement, LCD screen: Schritt 4, Bild 1 von 3 Nikon Coolpix L820 Device Ports Replacement, LCD screen: Schritt 4, Bild 2 von 3 Nikon Coolpix L820 Device Ports Replacement, LCD screen: Schritt 4, Bild 3 von 3
    • Remove the front casing to expose the LCD screen and wires.
    • Do not damage the exposed wires.
  5. Nikon Coolpix L820 Device Ports Replacement: Schritt 5, Bild 1 von 3 Nikon Coolpix L820 Device Ports Replacement: Schritt 5, Bild 2 von 3 Nikon Coolpix L820 Device Ports Replacement: Schritt 5, Bild 3 von 3
    • Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
  6. Nikon Coolpix L820 Device Ports Replacement: Schritt 6, Bild 1 von 2 Nikon Coolpix L820 Device Ports Replacement: Schritt 6, Bild 2 von 2
    • Once the flexible ribbon wires are disconnected, remove the LCD screen.
  7. Nikon Coolpix L820 Device Ports Replacement, Device Ports: Schritt 7, Bild 1 von 1
    • Begin by removing these five screws
  8. Nikon Coolpix L820 Device Ports Replacement: Schritt 8, Bild 1 von 1
    • From there, the panel covering the motherboard can be removed.
  9. Nikon Coolpix L820 Device Ports Replacement: Schritt 9, Bild 1 von 2 Nikon Coolpix L820 Device Ports Replacement: Schritt 9, Bild 2 von 2
    • Using the pointed end of the spudger, lift the hinges that secure these four flex circuits.
  10. Nikon Coolpix L820 Device Ports Replacement: Schritt 10, Bild 1 von 2 Nikon Coolpix L820 Device Ports Replacement: Schritt 10, Bild 2 von 2
    • Once the flex circuits are removed, the motherboard can be lifted and the device can be accessed for replacement.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Marc
430 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-4, Miles Spring 2015 Mitglied von UMass Dartmouth, Team 1-4, Miles Spring 2015
UMASSD-MILES-S15S1G4
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Could you explain how the power button is changed? Thank you!!
minigalinda - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,819
