Einleitung
The shutter is a very important part of the camera because without it you can't take pictures. This guide will give you the steps to access this button and replace this button.
Was du brauchst
Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
Remove the front top Phillips screw with the screwdriver.
Open the empty battery slot on the bottom of the camera, revealing four additional screws.
Unscrew the four Phillips screws with the screwdriver.
Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
Once the rear housing is separated, the settings buttons will be accessible for replacement.
Remove these five Phillips screws, from the back of the camera, with the Phillips screwdriver.
Using the pointed edge of the spudger, lift the hinge that secures this flex circuit. This will unfasten the flexible ribbon wire.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Muy bueno pero falta documentar 3 tornillos.
1. En el paso 1, en la tercera foto debajo del sticker del código de barras.
2. En el paso 2, justo en el fondo del compartimento de una de las baterías (la del extremo). Incluso se alcanza a apreciar en la foto.
3. En el paso 8, en esa misma pieza de metal a un lado está el otro tornillo.
My shutter button still works but doesn’t give feedback. It’s hard to tell when I’ve taken a picture because it doesn’t “click.” I’m wondering if that’s something that can be fixed, but I can’t tell if the mechanism for that feedback is in the mechanical portion above (and maybe a piece of metal broke) or built into the switch soldered on the circuit board.
Dove si può acquistare il bottone a buon prezzo? grazie
Where can you buy the button at a good price? Thank you
