Einleitung
If the shutter button on your Nikon Coolpix L830 is damaged, replacement is necessary. Following these steps will allow you to replace the broken button with a new one to allow complete shutter functionality to return.
Was du brauchst
Use a Phillips #000 screwdriver to unscrew the two 3.0mm Phillips screws located on the side of the camera with the HDMI port.
Unscrew the five 3.0mm Phillips #000 screws that are located on the bottom side of the camera.
Unscrew the 4.0mm Phillips #000 screw located underneath the grey flap on the side of the camera with the "DC IN 5.0 V" marker.
Unscrew the exposed 3.0mm Phillips #000 screw on the same side.
Press the flash button to open the flash component.
Remove the 3.0mm Phillips #000 screw located directly in-between the two arms.
Open the LCD monitor to reveal two 2.0mm Phillips screws.
Remove the 2.0mm Phillips #000 screws.
Insert a plastic opening tool between the back and front surface components of the camera.
Wiggle the plastic opening tool backwards and forwards along the top edge until the back surface comes off.
Gently pull the LCD ribbon connector up to allow the back casing to be completely removed.
Open the battery panel on the bottom of the camera by pushing the slider up and tugging the battery panel to the right.
Remove the 3.0mm Phillips screw in the top battery panel.
Remove the 3.0mm Phillips #000 screw located above the grey power flap on the side of the camera.
Use your finger to gently pull up the wire ribbon which connects the shutter button to the motherboard.
Insert the blue plastic opening tool between the main casing and the shutter component.
Wiggle the plastic opening tool up and down to pry off the shutter component.
Unscrew the single 2.0mm Phillips #000 screw located on the dark brown strip on the back of the shutter button panel.
Once the Phillips screw is removed, gently take off the metal component with your hand or a wedge tool.
Remove the final two 2.0mm Phillips #000 screws, releasing the shutter button.
