Zum Hauptinhalt wechseln
Nikon Coolpix L840 Buttons Replacement
Was du brauchst
    1. Nikon Coolpix L840 Buttons Replacement, Motherboard: Schritt 1, Bild 1 von 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: Schritt 1, Bild 2 von 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: Schritt 1, Bild 3 von 3
      • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
      Frag FixBot
      Kommentar hinzufügen
    2. Nikon Coolpix L840 Buttons Replacement: Schritt 2, Bild 1 von 1
      • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
      • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
      Frag FixBot
    3. Nikon Coolpix L840 Buttons Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix L840 Buttons Replacement: Schritt 3, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
      • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
      Frag FixBot
    1. Nikon Coolpix L840 Buttons Replacement, Buttons: Schritt 4, Bild 1 von 1
      • Unscrew the two, right-most, 2 mm screws with a Philips 000.
      • Unscrew the left-most, 4 mm screw with a Philips 000.
      Frag FixBot
    2. Nikon Coolpix L840 Buttons Replacement: Schritt 5, Bild 1 von 1
      • Slide off the button panel in the marked direction.
      Frag FixBot
    3. Nikon Coolpix L840 Buttons Replacement: Schritt 6, Bild 1 von 1
      • Flip to the front side of the button panel to access the button sensors.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 1-11, Maness Spring 2016 Mitglied von Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Mitglieder
25 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where can I get a replacement board for the buttons?
rush - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 58
Insgesamt: 3,163
