Einleitung
This guide details the steps required to replace the lanyard ring.
Was du brauchst
Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
Identify lanyard ring.
Unscrew the 4 mm black screw with a Philips 000.
Insert a metal spludger (or another sturdy tool with a thin tip) into the hole of the lanyard ring and lift the ring upwards and out of the camera.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
