Zum Hauptinhalt wechseln
Nikon Coolpix L840 Lanyard Ring Replacement
Was du brauchst
  1. Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: Schritt 1, Bild 1 von 3 Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: Schritt 1, Bild 2 von 3 Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
    Frag FixBot
    Kommentar hinzufügen
  2. Nikon Coolpix L840 Lanyard Ring Replacement: Schritt 2, Bild 1 von 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
    Frag FixBot
  3. Nikon Coolpix L840 Lanyard Ring Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix L840 Lanyard Ring Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
    Frag FixBot
  4. Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: Schritt 4, Bild 1 von 2 Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: Schritt 4, Bild 2 von 2
    • Identify lanyard ring.
    • Unscrew the 4 mm black screw with a Philips 000.
    Frag FixBot
  5. Nikon Coolpix L840 Lanyard Ring Replacement: Schritt 5, Bild 1 von 2 Nikon Coolpix L840 Lanyard Ring Replacement: Schritt 5, Bild 2 von 2
    • Insert a metal spludger (or another sturdy tool with a thin tip) into the hole of the lanyard ring and lift the ring upwards and out of the camera.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 1-11, Maness Spring 2016 Mitglied von Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 968
