Zum Hauptinhalt wechseln
Nikon Coolpix P100 Motherboard Access
Was du brauchst
  1. Nikon Coolpix P100  Motherboard Access, Nikon Coolpix P100  Motherboard Access: Schritt 1, Bild 1 von 1
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100  Motherboard Access: Schritt 2, Bild 1 von 3 Nikon Coolpix P100  Motherboard Access: Schritt 2, Bild 2 von 3 Nikon Coolpix P100  Motherboard Access: Schritt 2, Bild 3 von 3
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100  Motherboard Access: Schritt 3, Bild 1 von 1
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100  Motherboard Access: Schritt 4, Bild 1 von 1
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100  Motherboard Access: Schritt 5, Bild 1 von 1
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100  Motherboard Access: Schritt 6, Bild 1 von 2 Nikon Coolpix P100  Motherboard Access: Schritt 6, Bild 2 von 2
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100  Motherboard Access: Schritt 7, Bild 1 von 3 Nikon Coolpix P100  Motherboard Access: Schritt 7, Bild 2 von 3 Nikon Coolpix P100  Motherboard Access: Schritt 7, Bild 3 von 3
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100  Motherboard Access: Schritt 8, Bild 1 von 1
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100  Motherboard Access: Schritt 9, Bild 1 von 1
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100  Motherboard Access: Schritt 10, Bild 1 von 1
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100  Motherboard Access: Schritt 11, Bild 1 von 1
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100  Motherboard Access: Schritt 12, Bild 1 von 1
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100  Motherboard Access: Schritt 13, Bild 1 von 1
    • Now you have access to the camera's motherboard
Abschluss
Rikki Brown
267 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-1, Tanski Winter 2015 Mitglied von USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
y como cambia el lente si se atasca
djalfonsodaza - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 2,455
