Zum Hauptinhalt wechseln
Nikon Coolpix P100 Back Buttons Replacement
Was du brauchst
  1. Nikon Coolpix P100 Back Buttons Replacement, Back Buttons: Schritt 1, Bild 1 von 1
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Back Buttons Replacement: Schritt 2, Bild 1 von 3 Nikon Coolpix P100 Back Buttons Replacement: Schritt 2, Bild 2 von 3 Nikon Coolpix P100 Back Buttons Replacement: Schritt 2, Bild 3 von 3
    • On the left side of the camera, remove two screws using a Phillips #00 screwdriver.
  3. Nikon Coolpix P100 Back Buttons Replacement: Schritt 3, Bild 1 von 1
    • On the right side of the camera, remove the first visible screw.
  4. Nikon Coolpix P100 Back Buttons Replacement: Schritt 4, Bild 1 von 1
    • Lift the HDMI and A/V OUT cover to access the hidden screw.
  5. Nikon Coolpix P100 Back Buttons Replacement: Schritt 5, Bild 1 von 1
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Back Buttons Replacement: Schritt 6, Bild 1 von 2 Nikon Coolpix P100 Back Buttons Replacement: Schritt 6, Bild 2 von 2
    • Remove the two screws hidden underneath the display panel.
  7. Nikon Coolpix P100 Back Buttons Replacement: Schritt 7, Bild 1 von 3 Nikon Coolpix P100 Back Buttons Replacement: Schritt 7, Bild 2 von 3 Nikon Coolpix P100 Back Buttons Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to gently loosen up the sides of the camera.
  8. Nikon Coolpix P100 Back Buttons Replacement: Schritt 8, Bild 1 von 2 Nikon Coolpix P100 Back Buttons Replacement: Schritt 8, Bild 2 von 2
    • Carefully open the camera.
    • There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
  9. Nikon Coolpix P100 Back Buttons Replacement: Schritt 9, Bild 1 von 2 Nikon Coolpix P100 Back Buttons Replacement: Schritt 9, Bild 2 von 2
    • This is the cover that houses the back buttons of the camera. Turn it around.
  10. Nikon Coolpix P100 Back Buttons Replacement: Schritt 10, Bild 1 von 1
    • Remove the six indicated screws.
  11. Nikon Coolpix P100 Back Buttons Replacement: Schritt 11, Bild 1 von 2 Nikon Coolpix P100 Back Buttons Replacement: Schritt 11, Bild 2 von 2
    • Use a plastic opening tool to lift the metal plate and set it aside.
  12. Nikon Coolpix P100 Back Buttons Replacement: Schritt 12, Bild 1 von 3 Nikon Coolpix P100 Back Buttons Replacement: Schritt 12, Bild 2 von 3 Nikon Coolpix P100 Back Buttons Replacement: Schritt 12, Bild 3 von 3
    • Turn the cover around and push against the buttons.
  13. Nikon Coolpix P100 Back Buttons Replacement: Schritt 13, Bild 1 von 1
    • Now you have partial access to one set of buttons.
  14. Nikon Coolpix P100 Back Buttons Replacement: Schritt 14, Bild 1 von 1
    • Find the last set of removal buttons on the bottom left.
  15. Nikon Coolpix P100 Back Buttons Replacement: Schritt 15, Bild 1 von 1
    • Remove the screw.
  16. Nikon Coolpix P100 Back Buttons Replacement: Schritt 16, Bild 1 von 2 Nikon Coolpix P100 Back Buttons Replacement: Schritt 16, Bild 2 von 2
    • Use a plastic opening tool to remove the button.
Abschluss
Nghiem Ngo
330 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-1, Tanski Winter 2015 Mitglied von USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 814
