Einleitung
If you have a jammed button or if you simply want to replace a part on your Nikon Coolpix P100 camera, then this guide is perfect for you! This guide will help users easily replace a broken back button on your Nikon Coolpix P100 camera.The only required tools you need are a Phillips #00 Screwdriver and a iFixit Opening Tool.
Before using this guide make sure that the camera is powered off!
Was du brauchst
On the left side of the camera, remove two screws using a Phillips #00 screwdriver.
