Zum Hauptinhalt wechseln
Nikon Coolpix P510 Battery Removal Replacement
Was du brauchst
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: Schritt 1, Bild 1 von 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix P510 Battery Removal Replacement: Schritt 2, Bild 2 von 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
Abschluss
Brian Hulsey
1.461 Reputation
6 Anleitungen geschrieben
Colorado Springs, Team 2-2, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-2, Panko Spring 2015
UCCS-PANKO-S15S2G2
3 Mitglieder
12 Anleitungen geschrieben
3 Kommentare
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - Antwort
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - Antwort
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 29
Insgesamt: 4,172
