Zum Hauptinhalt wechseln
Nikon Coolpix P510 LCD Replacement
Was du brauchst
  1. Nikon Coolpix P510 LCD Replacement, Battery Removal: Schritt 1, Bild 1 von 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 LCD Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix P510 LCD Replacement: Schritt 2, Bild 2 von 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
  3. Nikon Coolpix P510 LCD Replacement, LCD Screen Window: Schritt 3, Bild 1 von 2 Nikon Coolpix P510 LCD Replacement, LCD Screen Window: Schritt 3, Bild 2 von 2
    • Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
  4. Nikon Coolpix P510 LCD Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix P510 LCD Replacement: Schritt 4, Bild 2 von 2
    • Take the four 4mm PH00 Phillips screws out.
  5. Nikon Coolpix P510 LCD Replacement: Schritt 5, Bild 1 von 2 Nikon Coolpix P510 LCD Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to trace around the screen to pop the front and back section apart.
  6. Nikon Coolpix P510 LCD Replacement, LCD: Schritt 6, Bild 1 von 2 Nikon Coolpix P510 LCD Replacement, LCD: Schritt 6, Bild 2 von 2
    • Tilt the LCD up to get access to the back of it.
  7. Nikon Coolpix P510 LCD Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix P510 LCD Replacement: Schritt 7, Bild 2 von 2
    • Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
  8. Nikon Coolpix P510 LCD Replacement: Schritt 8, Bild 1 von 1
    • The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
    • It may take a little bit of pressure to get the chip off. Be gentle to make sure you don't break the chip.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Brian Hulsey
1.461 Reputation
6 Anleitungen geschrieben
Colorado Springs, Team 2-2, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-2, Panko Spring 2015
UCCS-PANKO-S15S2G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 64
Insgesamt: 5,450
