Zum Hauptinhalt wechseln
Nikon Coolpix P530 Battery Replacement
Was du brauchst
  1. Nikon Coolpix P530 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: Schritt 2, Bild 1 von 3 Nikon Coolpix P530 Battery Replacement: Schritt 2, Bild 2 von 3 Nikon Coolpix P530 Battery Replacement: Schritt 2, Bild 3 von 3
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: Schritt 3, Bild 1 von 3 Nikon Coolpix P530 Battery Replacement: Schritt 3, Bild 2 von 3 Nikon Coolpix P530 Battery Replacement: Schritt 3, Bild 3 von 3
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix P530 Battery Replacement: Schritt 4, Bild 2 von 2
    • Gently remove the battery from the chamber.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Thanks. Just checking the camera issues.
Suzanne von Leuschner - Antwort
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - Antwort
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 3,558
