Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This is the first part to taking apart your Nikon Coolpix S210.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place thumb on the battery cover panel on the bottom of the device.
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Slide the orange latch outward towards the corner of the camera. The battery should pop out.
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  5. Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  6. Unscrew the two 4.05mm screws on the side next to the buttons.
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  7. Gently wedge the flat end of the spudger between the back case and the wrist-strap mount. The wrist-strap mount is the thin metal piece on the side of the camera.  Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
Abschluss
To reassemble your device, follow these instructions in reverse order, paying careful attention to the locations of the different sizes of screws.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Paul Doyle
470 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 5-17, Amido Winter 2011 Mitglied von Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 Mitglieder
7 Anleitungen geschrieben
What about the front case so I can replace the flash board on top?
danwat1234 - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 2,037
