Zum Hauptinhalt wechseln
Nikon Coolpix S210 LCD screen Replacement
Was du brauchst
  1. Nikon Coolpix S210 LCD screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 LCD screen Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix S210 LCD screen Replacement: Schritt 2, Bild 2 von 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nikon Coolpix S210 LCD screen Replacement, Back Case: Schritt 3, Bild 1 von 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 LCD screen Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 LCD screen Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 LCD screen Replacement: Schritt 6, Bild 1 von 2 Nikon Coolpix S210 LCD screen Replacement: Schritt 6, Bild 2 von 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 LCD screen Replacement, LCD screen: Schritt 7, Bild 1 von 3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: Schritt 7, Bild 2 von 3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: Schritt 7, Bild 3 von 3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 LCD screen Replacement: Schritt 8, Bild 1 von 1
    • Gently remove the LCD screen.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Mallory Arend
444 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-17, Amido Winter 2011 Mitglied von Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 3,978
