Zum Hauptinhalt wechseln
Einleitung
This guide will teach you how to remove the outer cover of your Nikon Coolpix S220 camera. It is an easy and fast process that most people should be able to accomplish with nothing but a small screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two 2.8 mm screws on the left side of the camera.
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Remove the four 2.8 mm screws on the right side of the camera.
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Remove the three 4.1 mm screws on the bottom of the camera.
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Gently lift the rear cover from the camera.
    • Gently lift the rear cover from the camera.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Shauna
750 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 12-32, Maness Spring 2011 Mitglied von Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 4,692
