Zum Hauptinhalt wechseln
Nikon Coolpix S30 LCD Screen Replacement
Was du brauchst
  1. Nikon Coolpix S30 LCD Screen Replacement, Batteries: Schritt 1, Bild 1 von 2 Nikon Coolpix S30 LCD Screen Replacement, Batteries: Schritt 1, Bild 2 von 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
    Frag FixBot
    Kommentar hinzufügen
  2. Nikon Coolpix S30 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix S30 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
    Frag FixBot
  3. Nikon Coolpix S30 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the batteries by gently tipping the camera.
    Frag FixBot
  4. Nikon Coolpix S30 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • FIRST: remove the batteries.
    • Unscrew the four screws around the corners of the camera. This can be done using the iFixit kit's T5 (star tip screwdriver)
    Frag FixBot
  5. Nikon Coolpix S30 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the screw on the left (silver) first. It can be removed with the same tip (T5)
    • Change screwdriver tip to iFixit kit's PH000. This removes the screw on the right (black) It is a small Phillips head.
    Frag FixBot
  6. Nikon Coolpix S30 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Gently separate the back panel from the rest of the camera.
    Frag FixBot
  7. Nikon Coolpix S30 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove screw connecting the top right of the screen to the mother board.
    Frag FixBot
  8. Nikon Coolpix S30 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Spin the camera around and gently pull the screen towards you. This will allow easy access to components on the motherboard.
    Frag FixBot
  9. Nikon Coolpix S30 LCD Screen Replacement: Schritt 9, Bild 1 von 2 Nikon Coolpix S30 LCD Screen Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove connected strip by flipping up the small off-white plastic strip with tweezers.
    • Gently pull out the strip from the motherboard.
    Frag FixBot
  10. Nikon Coolpix S30 LCD Screen Replacement: Schritt 10, Bild 1 von 2 Nikon Coolpix S30 LCD Screen Replacement: Schritt 10, Bild 2 von 2
    • Remove screw that is now in the top right corner. This will detach the screen entirely.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Penn State, Team 2-4, Kaschak Winter 2015 Mitglied von Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 1,254
