Einleitung
When you are in a situation whether your LCD screen is malfunctioning, this guide will assist you to find the problem.
Was du brauchst
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
Remove the two screws.
Gently pull up to detach the frame. (picture 2)
3 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
No mention of getting an electric shock while removing the case.Bit of a tingle anyway.I held the camera in a plastic bag after that.
This will probably not be replied to, but is there any reliable way to discharge the flash capacitor? Got shocked once, but I thought it was already discharged lol.
Connect a 1k ohm resister between the black and red wire from the capacitor. Give it a few moments to discharge through the resistor. Don't discharge the capacitor without a resistor as you run a good chance of destroying the electronics. Wear your latex gloves too.
Easy to follow
