Einleitung
If you shutter lens does not seem to operate, these guides will help you find the problem.
Was du brauchst
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
Remove the two screws.
Gently pull up to detach the frame. (picture 2)
11 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
Nikon coolpix s3100 lens mocking place help my
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
I have same issue it shutter half opens and doesnt open correctly
my LCD screen is stuck on white after after i did this :(
