Zum Hauptinhalt wechseln
Nikon Coolpix S33 Battery and SD Card Replacement
Was du brauchst
  1. Nikon Coolpix S33  Battery and SD Card Replacement, Battery and SD Card: Schritt 1, Bild 1 von 2 Nikon Coolpix S33  Battery and SD Card Replacement, Battery and SD Card: Schritt 1, Bild 2 von 2
    • Make sure that your camera is turned off before beginning any replacement of parts.
    • Flip the camera over to the Battery/SD Card compartment at the bottom right of your camera, located directly under the Coolpix logo.
    • This slot is for the camera's battery.
    • This slot is for the camera's SD card.
    • Open up the compartment of the camera as shown in the images.
    • No tools are necessary for this replacement.
    • Using your finger, push on the latch in the direction of the arrow to release the battery from the locking mechanism holding it in your camera.
    • Push down the SD card to release it from the locking mechanism in your camera.
    • Once the Battery and SD Card are loose, you can pull them out of their respective slots.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 16-3, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 54
Insgesamt: 4,181
