Einleitung
This guide is a walk through on how to replace/install your battery and/or SD card for your camera.
Was du brauchst
Make sure that your camera is turned off before beginning any replacement of parts.
Flip the camera over to the Battery/SD Card compartment at the bottom right of your camera, located directly under the Coolpix logo.
This slot is for the camera's battery.
This slot is for the camera's SD card.
Using your finger, push on the latch in the direction of the arrow to release the battery from the locking mechanism holding it in your camera.
Push down the SD card to release it from the locking mechanism in your camera.
Once the Battery and SD Card are loose, you can pull them out of their respective slots.
4 weitere Personen haben diese Anleitung absolviert.
