Zum Hauptinhalt wechseln
Nikon Coolpix S33 Speaker Replacement
Was du brauchst
    1. Nikon Coolpix S33 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nikon Coolpix S33 Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 2
      • Remove battery before initiating this step to avoid the possibility of electric shock.
      • Remove all four T5 Torx screws from the exterior of the camera.
      • Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
      Frag FixBot
      Kommentar hinzufügen
    2. Nikon Coolpix S33 Speaker Replacement: Schritt 2, Bild 1 von 1
      • Remove the two screws located above the HDMI and USB logos that are inside the camera's battery compartment using a JIS000 screwdriver.
      Frag FixBot
    3. Nikon Coolpix S33 Speaker Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix S33 Speaker Replacement: Schritt 3, Bild 2 von 2
      • Using a plastic opening tool, gently remove the back cover from the camera.
      Frag FixBot
    1. Nikon Coolpix S33 Speaker Replacement, LCD: Schritt 4, Bild 1 von 1
      • Be sure to have followed the steps to remove the Back Cover of your camera before beginning to replace the LCD Screen. This guide will cover just the replacement of the LCD Screen.
      • Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
      Frag FixBot
    2. Nikon Coolpix S33 Speaker Replacement: Schritt 5, Bild 1 von 1
      • Before pulling the LCD Screen out of the camera, you will need to disconnect the ribbon connector that attaches the screen to the camera.
      • Gently pull the ribbon connector out of it's slot. You should be able to remove it without the need of any tools.
      Frag FixBot
    1. Nikon Coolpix S33 Speaker Replacement, Speaker: Schritt 6, Bild 1 von 2 Nikon Coolpix S33 Speaker Replacement, Speaker: Schritt 6, Bild 2 von 2
      • Remove the screws. Gently pry off the LCD holder using a plastic opening tool.
      Frag FixBot
    2. Nikon Coolpix S33 Speaker Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix S33 Speaker Replacement: Schritt 7, Bild 2 von 2
      • After removing the LCD holder, you can begin the process of removing the speaker from the camera.
      • Remove the 15'' Phillips screw using a PH#00 screwdriver.
      • Gently pry off the green flap to get access to the speaker port.
      Frag FixBot
    3. Nikon Coolpix S33 Speaker Replacement: Schritt 8, Bild 1 von 1
      • Gently pull out the speaker using the green and white wires.
      • Disconnect these wires from the motherboard.
      Frag FixBot
Abschluss
USF Tampa, Team 16-3, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 41
Insgesamt: 1,030
