Zum Hauptinhalt wechseln
Nikon Coolpix S3500 Battery and memory card door Replacement
Was du brauchst
  1. Nikon Coolpix S3500 Battery and memory card door Replacement, Battery and memory card door: Schritt 1, Bild 1 von 1
    • Take the device in your hand, and hold it with the shutter side of the device facing upward.
  2. Nikon Coolpix S3500 Battery and memory card door Replacement: Schritt 2, Bild 1 von 1
    • With the shutter still facing up, make sure the battery door is facing your opposite hand.
    • Using your free hand, pick up your new battery door.
  3. Nikon Coolpix S3500 Battery and memory card door Replacement: Schritt 3, Bild 1 von 1
    • Make sure that the new battery door is groove side up so that the door will slide onto the metal bracket on the device.
  4. Nikon Coolpix S3500 Battery and memory card door Replacement: Schritt 4, Bild 1 von 1
    • Line up the grooves on the battery door with the metal bracket and press the door towards the device.
    • The battery door is held on by tabs. Make sure that the tabs click into place on the door.
Abschluss
Sam Houston State, Team 2-1, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 2-1, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 640
