Zum Hauptinhalt wechseln
Nikon Coolpix S3500 Rear Buttons Replacement
Was du brauchst
  1. Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: Schritt 1, Bild 1 von 2 Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: Schritt 1, Bild 2 von 2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 2, Bild 2 von 2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 3, Bild 2 von 2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 4, Bild 2 von 2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 5, Bild 1 von 3 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 5, Bild 2 von 3 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 5, Bild 3 von 3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 6, Bild 1 von 2 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 6, Bild 2 von 2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Rear Buttons  Replacement, Rear Buttons: Schritt 7, Bild 1 von 1
    • Take the rear panel of the device in the palm of your hand with the buttons facing downward.
  8. Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 8, Bild 1 von 3 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 8, Bild 2 von 3 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 8, Bild 3 von 3
    • On the back side of the device's rear panel, you will see the plastic brackets that hold the rear function buttons in place.
    • With your other hand, take the pry tool and start working your way around the edge of the buttons
  9. Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 9, Bild 1 von 2 Nikon Coolpix S3500 Rear Buttons  Replacement: Schritt 9, Bild 2 von 2
    • Now, take the hand that was previously holding the pry tool, and finish pulling off the rear function buttons.
Abschluss
Sam Houston State, Team 2-1, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 2-1, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 443
