Einleitung
If the camera is not outputting any audio or the sound is muffled, then the speaker might need replacing.
  1. Slide the battery door open with a finger or thumb and release it so the door opens.
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Push the orange tab back and the battery will pop out.
    • Push the orange tab back and the battery will pop out.
  3. Remove four 2mm Phillips #000 screws. Remove two black 3mm Phillips #000 screws. Remove one 4mm Phillips #000 screws.
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart. Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Turn the camera over. Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera. Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Remove the single 3mm Phillips #000 screw from the back of the camera.
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  8. Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing. Desolder the two wires connecting the casing to the motherboard.
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
  9. Remove the single  2mm Phillips #000 screw.
    • Remove the single 2mm Phillips #000 screw.
  10. Use the flat end of a spudger to lift up the black tabs on the ZIF connectors. Pull the ribbon cables out of the ZIF connectors. Pull the ribbon cables out of the ZIF connectors.
    • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
  11. Grabbing the top left corner of the screen, pull it up until the screen comes completely off. Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
    • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
  12. Remove the two 3mm Phillips #000 screws. Remove the two 3mm Phillips #000 screws.
    • Remove the two 3mm Phillips #000 screws.
  13. Turn the camera over and remove a single 4mm Phillips #000 screw. There may be black tape covering the screw.
    • Turn the camera over and remove a single 4mm Phillips #000 screw.
    • There may be black tape covering the screw.
  14. Use the flat end of a spudger to flip up the black tabs on the ZIF connectors. Pull the ribbon cables out of the ZIF connectors.
    • Use the flat end of a spudger to flip up the black tabs on the ZIF connectors.
  15. Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body. The tabs are brittle so use gently force.
    • Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body.
    • The tabs are brittle so use gently force.
  16. Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the orange ribbon cable out of the ZIF connector.
    • Separate the lens from the motherboard.
  17. Slide the speaker out from the bottom of the speaker piece. Slide the speaker out from the bottom of the speaker piece.
    • Slide the speaker out from the bottom of the speaker piece.
Abschluss
Matina Newsom
747 Reputation
8 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 32
