Einleitung
If you need to replace the video record, playback, or camera mode buttons, then you must follow these steps to replace the metal plate with the mounted wiring.
Was du brauchst
Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
There are 2 on each side, and 4 on the bottom.
Remove the black casing on the back of the camera that runs around the LCD screen.
Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
