Einleitung
This guide will go through the steps to properly and safely remove the LCD screen from your Nikon Coolpix S630 for repair, replacement, or maintenance.
Was du brauchst
The battery compartment is located on the bottom of the camera.
Place your thumb on the battery door.
Slide the door away from the camera in the direction the arrow points to.
Slide the yellow tab towards the back of the camera.
The battery should pop out.
Remove the battery.
Press the memory card down into the camera.
The memory card should pop out.
Remove the memory card.
Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
Gently pull the ribbon from the logic board with tweezers.
With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
Lift LCD screen carefully from the metal casing
Lift the two tabs for both ribbons with a plastic case opener like in the previous step
Pull out ribbons gently from the logic board with tweezers to disconnect screen
Eine weitere Person hat diese Anleitung absolviert.
