Einleitung
This guide shows how to remove a broken internal component for navigation buttons.
Was du brauchst
Place the camera facing upwards.
Press down on the battery cover and slide towards the front face of the camera.
Locate the eight outer PH 2mm screws on the device.
Using the PH00 screwdriver remove all of the screws from the camera.
Using a plastic opening tool, gently pry off the front and rear plates.
Be patient with this step, do not force the clips holding the plates together.
Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
