Zum Hauptinhalt wechseln
Nikon Coolpix S6300 Display Replacement
Was du brauchst
  1. Nikon Coolpix S6300 Display Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Display Replacement: Schritt 2, Bild 1 von 1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Display Replacement, Buttons: Schritt 3, Bild 1 von 3 Nikon Coolpix S6300 Display Replacement, Buttons: Schritt 3, Bild 2 von 3 Nikon Coolpix S6300 Display Replacement, Buttons: Schritt 3, Bild 3 von 3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Display Replacement: Schritt 4, Bild 1 von 3 Nikon Coolpix S6300 Display Replacement: Schritt 4, Bild 2 von 3 Nikon Coolpix S6300 Display Replacement: Schritt 4, Bild 3 von 3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Display Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Display Replacement: Schritt 6, Bild 1 von 1
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Display Replacement: Schritt 7, Bild 1 von 1
    • You may now remove the internal panel of the buttons
  8. Nikon Coolpix S6300 Display Replacement, Display: Schritt 8, Bild 1 von 1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
Abschluss
Hung
383 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-2, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
Lisa F - Antwort
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
Geo Nik - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 1,425
