Zum Hauptinhalt wechseln
Nikon Coolpix S7000 Shutter Button Replacement
Was du brauchst
  1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: Schritt 1, Bild 1 von 2 Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: Schritt 1, Bild 2 von 2
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Nikon Coolpix S7000 Shutter Button Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix S7000 Shutter Button Replacement: Schritt 2, Bild 2 von 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Shutter Button Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix S7000 Shutter Button Replacement: Schritt 3, Bild 2 von 2
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Nikon Coolpix S7000 Shutter Button Replacement: Schritt 4, Bild 1 von 3 Nikon Coolpix S7000 Shutter Button Replacement: Schritt 4, Bild 2 von 3 Nikon Coolpix S7000 Shutter Button Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
Abschluss
USF Tampa, Team S2-G3, Lacy Spring 2017 Mitglied von USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
shutter keeps trying to open. clicks slighly and does not open
Beatrix - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 734
