Einleitung
This guide will teach owners how to replace their battery if it is defective or exhibits signs of a declining battery life.
Ersatzteile
  1. Using plastic tool, open battery cover located on the bottom, left of the camera, if the camera lens were facing you.
    • Using plastic tool, open battery cover located on the bottom, left of the camera, if the camera lens were facing you.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Remove battery from battery slot. Place new battery in slot and make sure the negative side is on the left side.
    • Remove battery from battery slot.
    • Place new battery in slot and make sure the negative side is on the left side.
    • Battery Access Door was unavailable
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ilyasah Muhammad
234 Reputation
2 Anleitungen geschrieben
Baylor, Team S2-G6, Johnson Spring 2018 Mitglied von Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 84
